Michael J.
I was experiencing a ragged throttle response on a 90 XJS conv. with V-12 and Marelli ignition. Throttle potentiometer voltage was checked and found to be good. Idle was smooth, although high (1200 rpm). Open throttle and the engine got rough like a bad throttle pot.
I disconnected the red vacuum line for the Marelli ignition module and everything smoothed out. My guess is that the sensor for the ignition ECU that advances or retards timing is shot. I'm now trying to find another ignition ECU. Reconnect the vacuum line and the problem occurs again. /ubbthreads/images/graemlins/confused.gif
