Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
Searched the archive for info on this. First time dismantling the valve train on a 948cc motor. Once the cotter pin and end washers come off, do the rockers and pedestals slide off fairly easily or is it more of a press fit? Thanks for the advice
You should find that it will all slide apart easily, pay close attention to the order of things. spacers and springs and shims if there are any. inspect for worn bushings and shaft wear.
So its all apart and clean, and i can definitely feel some wear grooves with my fingernail under a couple of the spots where the rockers were--- sounds like advice of this group is replace the shaft
Use to be a place in Calif. I think that repaired, rebuilt rocker arm assys. Site address no longer works. sigh. They had good prices as well just over 100 bucks as I remember, used new shaft and bored all the rockers.
You could just get a new shaft and check for fit of the rocker arms.
If they turn freely without binding or are too loose, tested by rocking sideways (front/rear with car), they should be ok.
If you really want to do more,get a set of offset bushings from APT.
They press in easily and ream them out to 9/16 with a straight reamer. Then you have a nice high performance set that doesn't look any different than stock.
They sell the shaft for around 50
