kyreb1862
A couple of times now I have had to top off my master cylinder on my 77 B. I have replaced most of my brake components such as flex lines, wheels cylinders, pads and shoes. I can't observe any fluid leaking from the drums or calipers. The brake pedal feels good and there are no leaks around the master cylinder. I don't think I have my brakes adjusted right so is there a possibility that the pistons in the wheel cylinders have pushed out? How could I tell if fluid was getting sucked out through the brake booster? /ubbthreads/images/graemlins/confused.gif
Hi Guest!
