Got most of the lights (head and rear and brake lights (lamps)) working on my 62' Sprite but can't get the front or rear flashers to light much less flash. The front flasher units (the small light under the headlight) each have a single bulb with double filament (an on-filament and a flasher filament, I assume).
I’ve installed a new flasher unit.
My hunch is that I don’t have the wires correctly plugged into the switch (I have the wiring diagram, (#26 “combined direction indicator/headlamp flasher switch, but its not helping). The switch is a complicated gizmo with six prongs in the back??
Anybody have access to other diagrams or experience with this issue?
