John Morralee
The flasher unit on my AH '63 BJ7 failed,it was the original one with the L shaped bracket used to secure it to the frame.A new 'off the shelf'replacement works except the pilot light is on permanently when the ignition is on. It winks as it should when the indicator is operated. On the new one the B letter is replaced by an X. The P and L are as the old one. Is the problem to do with the cars being positive earth ( tho. the unit does not appear to need to be earthed) Do I need a negative earth if such an animal exists?
