Tinster
angelfj said:I may be wrong but I don't believe we (or Dale) have any idea as what engine work was done, e.g. how fresh the valves are or in fact if anything was done to the cyl. head and valve train.
Dale: Can you confirm this?
fja
<span style="color: #660000">Confirmed- zero ideas what might have been done to
the engine itself. I've had the valve cover off twice- once to find TDC and
another time to adjust the valves. If DPO Pedro didn't spend the cash for
an oil change in the 3 years he owned the car, I seriously doubt his junkyard
mechanic attempted any major engine work.
My car starts, that's not the issue here.
The issue is it used to start much more easily, like
on the first turn of the key. Paul is probably correct
with his weather theory. It is much cooler now.
regards,
d</span>
