robert_ellison
I am having difficulty shifting, especial\y into 1st gear and also downshifting into 2nd & 1st gear. Any likely reasons for this?
robert_ellison said:I am having difficulty shifting, especial\y into 1st gear and also downshifting into 2nd & 1st gear. Any likely reasons for this?
<span style="color: #FF0000">The plunger is attached to the lower bellhousing on the passenger side</span>. It can be seen near the starter. To verify the plunger is working properly you need to raise the car up and put on jackstands, then have someone operate the clutch pedal while you look under the car near the starter. <span style="color: #FF0000">It should travel about 1-1/2"</span>. If it doesn't it needs to be bled. There's a bleed screw on top of the hydraulic clutch. <span style="color: #FF0000">BTW it's called the slave cylinder.</span>robert_ellison said:thanks for the replies. Where is the hydraulic clutch plunger? at the clutch or on the firewall? I also notice that when starting the car with the clutch all the way to the floor the car tends to move forward a bit. The clutch has been bled.
How can I tell if it has disengaged fully?
