scottkilpatrick
Hi I am new here and have just taken ownership of my dream car a 1962 TR4 - no overdrive.
There are numerous things I am doing right off the bat to sort of set a baseline since I didn’t get any maintainance records. What I’ve done so far:
1. Oli and Filter drain and refill
2. Diff/Axel oil drain and refill
3. Gearbox oil drain and refill
There were two items up next that I was thinking about addressing
1. Radiator drain, flush and refill
The more I research on this the more I am not sure if its a good idea or the complexity. Opinions welcome.
2. Brakes/Clutch master cylinder drain/refill
I know nothing of how to do this, if its a good idea and the level of difficulty.
I was also planning on changing the brake pads while doing this and again not sure of the difficulty.
When I apply the brakes they seem to work fine (squeak due to dirt or whatever), the pedal slowly sinks down and then when I let up they seems to start over at the top of pressure - not sure if that makes sense or is clear or if that’s normal.
Opinions welcome. Thanks all
Hi Guest!
