I've encountered a problem setting up my solid-axle TR4A's differential. I think I know what's going on, but I thought it best to pass it by you guys, in the hope that you might have more insight.
I clearly got the setup wrong first time I did it. This week I pulled the axle and checked the mesh with gear-marking compound, and it clearly wasn't right. The marks indicated that I should move the ring gear out of mesh, but the backlash was already at the spec maximum (0.006 inches). Anyway, by time I moved the ring gear enough to get a reasonable pattern, the backlash was 0.020 inches. That strikes me as way too much. I'm using a used ring and pinion set, so I'm prepared to go outside the specs a little, if necessary, but not that much.
My guess is that the gears are just worn. Do any of you agree, or have other ideas?
