Evening everyone. I have a couple of questions about my 73 TR6.
1)Can the axle shaft bearing and oil seal on the differential be changed w/o dropping the whole differential?
2)I was looking at GoodParts Axle/Hub Assembly, CV Joint kit for the stock differential. Has anyone used these and if so what were your experiences?
Did you like them? Ease of installation, etc. I know some grinding of the trailing arm housing is required to remove any ridges.
Thank You in advanced for any answers suggestions etc.
Thank You
Jerry
1973 TR6
Thank You
Jerry
1973 TR6
Hi Guest!
