Differential Ratio
vping
I have three rears (no laughing). One is from a 1969 AH Sprite. One is from a 1971 MG Midget & the other is from a 1972 MG Midget. How can I tell what the ratio of each is?
Is it stamped on the housing?
ChrisS
The teeth count will give you the ratio. It's stamped on / around the gears, but I forget were. They should be 4.22:1 (9x38 teeth), or 3.9:1 (10x39), or 3.73:1 (11x41). The early rears were 4.22, I'm not sure what was installed '69, but the '71 and '72 should be 3.9. The rubber bumber cars had the 3.73.
jollyroger
They are stamped in two places. You should find a stamped number on the top of the pumpkin on the right (passenger) side just below the mounting flange. It should be something like 9/38(4.22) or 10/39(3.9) or some other combination. Dividing those will get you the gear ratio. But...there is always a but, If someone has changed the gears it could be different. Soooo, look at the the ring gear, somewhere on it you will find the same numbers stamped on the flat outside portion of the ring gear. Divid the small one into the big un and there you have it.
Matthew E. Herd
Actually, so far as I can tell, only the latest RB cars were 3.73. Mine's a 3.9, and it's a 76. I think it was a '79 vintage effort to reduce highway revs a bit (somewhat hopeless at that point).
i had a 373, replaced it with a 39 best thing i ever did for that 1500. made a huge difference in standing start at a lite.
mark
Lol i didnt mention why i had to change it did I?? Um lets just say it failed to launch? the spider gears blew up. take a good look at the attach.
mark
spritenut
69 was the change year fro 4.22 to 3.9. the others are 3.9 for sure. There are numbers as others have said or just turn the input and count the revs. 4 and 1/4 = 4.22, almost 4 = 3.9 and 3 and 3/4 is a 3.77 or close enough by eye and hand turning.
vping
vping
I think the 69 Sprite might be a 4.22. This is soley based on the vin #. Says the car had a close ratio and a higher compression engine but I am not sure. I will count & see.
GB1
Very Good info
I believe that Midget\Sprites through 1500 were 4.2, then 3.9 with the intro of the 1500 and for the last few years (2?)of manufacture were 3.7
So probably all three of your diff's are 4.2
please correct me if I am wrong
jollyroger
I believe that all 1275 powered cars came with 3.9 diffs. that doesn't mean that they now all have them. I run 4.2 units in a number of my 1275 cars. Mine seem to like to run at 4000 to 4500 rpms at speed. 70 plus mph. However I could be wrong?
GB1
All 1275's that I have owned have been 4.2. The best way to check is by the stampings accurately named by above.
The RPM to MPH also depends on the tire sizes, it seems from your comparison that you are running a lower profile then OE. With OE diameter the MPH will be roughly twice the RPM's on a 4.22.
Please use the stampings or counting gears for an accurate comparison for the ratio's quoted above. Comparisons of RPM's/MPH's are not as accurate.
jollyroger
I agree, check the gearing from the ring gear if you really want to know. A quick way is to turn the drive shaft and count the turns of the shaft it takes to turn the rear wheel one rotation. If it is an open diff. while the axle is off the ground hold one wheel from turning and turn the driveshaft. count the turns of the driveshaft it takes to rotate the wheel one time then multiply that by two. That will give you the ratio. Are we confused yet. I could explain it further but my eyes would cross.
ChrisS
The data I have says that the ratio was changed from 4.22 to 3.9 in Dec. ’68 (HAN9-77591 / GAN4-66226) then again in Aug. ’77 (GAN6-200001) from 3.9 to 3.7. (Source Terry Horler).
Chris
jolly , i'll have to go and dig it out and take a look at it. i'll let ya know
mark
F Differential Ratio Sunbeam (Rootes) 3
M MK IX Differential Ratio Jaguar 1
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
Got_All_4 TR6 Differential side hub measurement Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
glemon General Tech Differential flange removal Triumph 11
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
J Flaking Paint Inside Differential Austin Healey 6
P TR2/3/3A Another Differential Question Triumph 22
P TR2/3/3A Differential question Triumph 6
DrEntropy MGB Differential with too much lash MG 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
L Wanted Tr6 differential Triumph Classifieds 9
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
R TR2/3/3A Sluge in Differential Triumph 21
J TR2/3/3A Differential Side Gear Backlash Triumph 3
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
H Clutch-Type Differential Austin Healey 5
K TR2/3/3A Correct oil level for differential? Triumph 5
W Differential oil for 100/4 1954 Austin Healey 14
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T Differential Pinion Bearings Austin Healey 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
oldbagpipe For Sale TR4 Detroit Locker Differential $1,000 Triumph Classifieds 3
Michael Oritt Spridget Differential Carrier--early versus late question Spridgets 1
D TR2/3/3A rear shelf differential dome Triumph 9
TomMull TR2/3/3A Differential housing spreader Triumph 3
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
KVH TR4/4A Removing the Differential Triumph 7
KVH TR4/4A TR4 Differential Removal and Seal Replacement Triumph 4
P Bt7 differential Austin Healey 6
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
T TR4/4A Differential clatter-solid axle Triumph 4
KVH General TR Rear Differential Seal Triumph 7
M TR6 Pressure differential warning assembly PDWA valve Triumph 4
K TR6 Goodparts Nissan differential swap Triumph 3
B TR6 TR6 Differential Followup, and inspection questions. How do you know it's good? Triumph 2
B TR6 TR6 Differential bearings. Triumph 3
maxwedge5281 differential interchange for big healey Austin Healey 6
