Differential Question?
Dadandson
This may seem like a silly question but what do the numbers of a differential signify? For example what difference would a 4:10 rear end be to say a 3:75? Is it more speed or more torque?
The lower the number the less the engine needs to turn to spin the rear wheels at the same speed.
So a 4.22 is faster off the line, but on the highway it runs at higher RPM's.
The 3.9's is what is mostly used for street cars that will be driven on the highway. A 3.7 is probably better but they get pricey. A 3.9 over a 4.2 will reduce highway rpm's by about 300. This is preferred to keep the temps down.
For autocrossing, a 4.5 or higher is preferred to keep the rpm's in the power band at a lower speed.
For racing it greatly depends upon the track, the length of the straight, whats before it, how many twisties, etc.
But basically for a street car a 3.9 is the preferred rear ratio.
Got it. Thanks
They signify the gear ratio. In other words, 4:1 means the input turns 4 times for every single turn of the output. A 3.75:1 (which I guess is what you meant) means the input turns 3.75 times for every turn of the output.
So a 4:1 is lower geared than a 3.75:1 - more RPM for the same MPH if you want to look at it that way. The 4.1:1 will give you a lower top speed than the 3.75:1 at maximum RPM, but will deliver more torque to the wheels.
Please also note that, though often used (or mis-used!) it's quite wrong to speak of the ratio of a differential. The differential is the component that allows one driven wheel to rotate at a different speed than the other, and it doesn't have a ratio per se. What you're referring to is the final drive ratio; pinion to ring gear is the term over here I think. I'd call it crown wheel and pinion ratio, being from across the pond.
Ocaasionally you'll see the ratios quoted as, e.g., 8:42. The means 8 teeth on the pinion and 42 on the crown wheel, for an overall 5.25:1 ratio, which will be familiar to most Austin Seven owners, incidentally.
specifically, it is the ratio of input to output. I.E. the the driveshaft has to turn 4.22 times to turn the wheels once
