regularman
The Datsun is a little lower in 1st. 4th is exactly the same as the Mowog.(input shaft locked to output shaft).losmorob said:Does anyone have a gear chart showing 210 vs ribcage ratios? I recently installed a 3.7 and i also have a 210 5-speed to install. If I remember, the 210 2nd is a bit taller, but 1,3 & 4 are similer in each trans. So adding the 5 speed will just give me similer ratios that i have now + a low 5th gear for those 70+ MPH trips down flat I5 in CA.
Hi Guest!
