Spridget64SC
If you are feeling it in the mesh of the gears then something has caused the ring gear to move in a side to side condition or the pinion gear to move in or out.
The shim goes between the pinion gear and the pinion end roller bearing cone. the distance tube goes between the two pinion bearing cones, over the pinion gear shaft. The distance tube is used for the drive shaft end bearing location. It determines the bearings preloads against their respective cups/races. The later diffs use a crush sleeve.
If your descriptions of "Gold-gild paint" and "Brass" are in actuality, aluminum (thinking your comment on it not being steel is based on a magnet check) in the honey-colored oil, from the case. One of the pinion bearing cups/races could have started spinning in the housing. Check the carrier bearings too. Sounds like a teardown is the only way to see what might be the actual culprit.
With a part number of STR520, the 3.545 was a Special Tuning only offering. Nothing standard production.
Failure diagnosis is never an easy task, in any business.
Mike
Mike
