Aldwyn
My dif's leak is getting worse and worse. I really need to put her up on jacks and find out where it's leaking! (looking under the car, it doesn't seem to be coming from the cover... more like it's coming from where the drive shaft meets the dif. (there appears to be oil all over the drive shaft)
Anyway, on to my question!
How the heck do I put more oil in the dif? I am afraid I will get low or run dry and start causing damage to the dif.
Bentley's only seems to show how to adjust levels by opening the drain screw, but not how to refill.
Any help would be appreciated!
Thanks!
Aldwyn
Thanks!
Aldwyn
Hi Guest!
