Daniel Kaminsky
Dieseling on my BJ8 since we put in new electronic ignition. Same 91 octane non-ethanol gas, rebuilt tuned carbs before ignition install, supposedly properly adjusted timing.... What else could it be??
That's the way I always do it. Mine runs on some times but not always and in almost all cases I want it in gear when I park, so I roll up to a stop, put it in 1st, turn key off, lift clutch.Then there is always this: let out the clutch and stall the engine after turning the ignition off.
If you buy your own timing light, make sure it is compatible with your electronic ignition. Some lights won't work with certain ignition electronics.
May not be related to healeys but worth checking thermostat and general cooling & ventilation we often get run on in marine engines with the issue of poor air flow usually run engine at idle for a period before shut down cures the problem.
It is very comforting to see how frequently so many of us need to stall the engine after shutting it off. It’s not a problem...it’s a feature.
I remember air-cooled VWs had an anti-dieseling solenoid on the carb which would shut off the flow of fuel from the float chamber when the ignition was turned off. Would that we had such a device on our HD-series carbs on the bottom between the float bowl and main jet.
