If you use conductive grease on bulbs... you'll short out the center contact to the lamp base. If you use conductive grease on the bullet connectors, there's always the possibility that it will ooze out and short to ground.
You can buy this stuff anywhere - they use it to thermally connect modern ignition modules to the distributor bodies. Without it, the modules burn out pretty swiftly - I suspect that some unprincipalled garages omit it through intention rather than ignorance so they can sell you a new module every 6 months.
It doesn't really matter how much you use (in bulb sockets) as long as it enought to exclude water - but there is no point in wasting it or having it smeared all over the place.
Plain Old Vaseline is used by many. I guess the notion is that the metal contacting metal still handles the conduction of electrons, but the goop prevents moisture from interfering with it.
that said, I paid a fist full ($40 or so) for a large tube of dielectric grease. I use it in spark plug boots, dist cap boots, etc.
