NutmegCT said:
My take: losing my email updates, and now the thread "new posts", makes it impossible for me to tell when a thread is updated (new post added).
I have to manually go to each forum, then open each thread, to see if there's an update. Only other way is to write down the timestamp of the Last Post in each thread. Over and over again.
Not good. Any work-around?
Thanks.
Tom
<span style="color: #009900">Once more with feeling </span> - I think I've mentioned this before - the lack of email notifications of new replies when using Watched Topics is a known "bug" in this BETA version of software and they are working on a fix (I hope) and it should be fixed (I hope) with the next Beta release. I can't go back to the old version without loosing every single post that has been made since the upgrade. You should still see the little watch glass next to topics. If not, try removing a topic from your watched list then re-adding it.
I have turned the new post tracking back on for the forum summary level (You may need to clear cookies to see it working again). This should allow you to see numbers in parans ( ) that tell you how many new posts and new replies are in each forum since your last visit (when viewing the forum summary).
What I have <span style="font-weight: bold">not</span> turned on is the tracking of new replies in the forums themselves. However, while you may not see a number, when you visit a forum, IF there are new replies to a thread, you will see the little folder icon to the left of a topic turned "yellow." Ok, so that will not tell you the exact number of new replies in that topic, but it will tell you there is at least ONE new reply since your last visit.
If you then click on a topic, it will take you to the first new unread reply. This should be a sufficient work around. Turing on the new reply "tracking counts" for the individual forums is a huge resource hog and does slow things down a lot, especially if there are a large number of members on the site at the same time.
However, you should still be able now to see which threads have new replies, just not how many - but as I said, when you enter a forum, you should still be able to see which threads have new replies by seeing which threads have the yellow icon lite up....then clickinig it will take you to the first new reply in the thread. I'm not sure that seeing a number tells you much more if you already can tell there is at least ONE new reply in a tread.
PS: IF YOU ARE NOT SEEING THE NEW POST/REPLY NUMBERS WHEN VIEWING THE FORUM SUMMARY PAGE, CLEAR YOUR COOKIES AND TRY AGAIN.
Cheers,
