Hello,
I have fitted my Dennis Welch vernier camshaft sprocket on my 29f BJ7 engine today. If I use the original lock washer the nut does not thread completely onto the camshaft. I have taken the lock washer off and used blue locktite and torqued the nut to 100 lbs, just wondering if others have had the same problem. If yes what was your solution. I am nervous about not using the lock washer, any comments on my solution would be apreciated.
Thanks Phil
Thanks Phil
Hi Guest!
