Pick up tube. The aluminum sump is thicker than the original sump yet the same basic outside dimensions. The high capacity pump appears slightly deeper too, but not sure about that. So there is an interference between the inside bottom of the sump and the pump.John,
Just curious. What part of the oil pump do you need to take almost a third of an inch off of, and why?
Including the engine in my car, the one for the car, and a spare 3000, all of three (3) them have beat to death oil pans. The one that's on the car was straightened out, but it has scars. In stock configuration, the original oil pan doesn't hang lower than the frame rails, but yet they look like they do :highly_amused:Randy,
Sounds like how I located the Cal Custom finned aluminum oil pan on the SBF motor. Put a piece of plywood across the bottom of the chasiss and make sure everything is above that. If it hangs below the chassis rails, you're going to have a problem sooner or later.
With the DW high out put pump you are going to have to reduce by at least the 0.3 inches. I will have to check up exactly how much from Bill Rawles ( I did not have the courage ) Then I had to flatten the filter to get the sump on.
A note to remember here, in my experience when adding the oil, 12 pints will take you above the level on the dip stick, 8 pints came up to the mark. I could not find any one from DW that could satisfactorily answer my questions on this, neither could Bill for that matter other than he told me that some of the racers start out with 18 pints in the engine.
Bob
Does anyone know a source now providing a suitable steel oil pan for the 6 cylinder healeys??
Thanks,
John
You also need to shorten the dip stick. You will see new exposed surface above the rubber cap - cut that much off. I confirmed the need to do this with the DW gang.
And just for the record 8 British pints came up to the original mark on the stick, I have added in more.
Bob
