John_Mc
Whilst rejuvenating my rear suspension, I noticed that the trailing arm box section of the frame had some "surface" rust (I also noticed what looks like signs of previous welding repairs). With my paint scraper I was able to locate a pin size hole...which on further evaluation seems to be able to accomodate a 2 inch diameter pin!
So it looks like I need to have that section repaired or replaced. The car is currently in a car port with no right rear suspension. Should I go ahead and proceed with my suspension repairs, then reassemble and drive carefully to a frame repair shop? Or do I need to rethink this entirely? (I'm afraid to think what lurks elsewhere). Is this a doable repair? What should I expect this to set me back (I figure I'll have it done to both sides since the left side looks worse, though it does have a repair done to it)?
then had them bend a 90 at 3 1/16 as per "blue print" cut away for "T" so it fits flat on out rigger, measure for bracket mounting holes etc.On the inside I put a 1/8 flat plate drilled to fit the bolts. after all was installed with the shims etc. in place I welded the seams as per diagram and used POR 15 on the top seam to keep water out.
make sure you get the larvea when you go after it. I've broken up a few 6's where one could literally hear them chewing away.
