Scott_Hower said:You can measure either, but it's probably easier/more accurate to use the pushrod. To do the valve, you need to know the rocker ratio.
so if i degree the cam, by measuring with a dial gauge the lift of the push rods I just use the published open/close specs?
But if I degree it from the valve I need to do a conversion of the rocker ratio? How do you do the conversion?
