2wrench
Okay. The rules are you must name the tool used and
explain how and when it is used in order to degree a
performance cam.
For instance: Would one need a tool to install and remove
crank gears? This is just an example.
Would one have to
use the crank gear puller to put the little sucker on there;
look at it (for diagnostics); pull it off and then put it
back on there again with the chain.
Would one be better off paying a mechanic, as a tool, who
knows what the !%%***%%## in sam !@&%$$$$ he knows he's
doing, because one bit off more than they can chew....and
they don't want to have to take the whole enchilada
(no race implications) apart again?
In the last week I've gotten my crank gear spacer on after
I notched it to slide over the key on the crank for a few
reasons (typical answer for other-than-pro-mechanic).
Long-winded....I'll shut up.
PS: Hope you win.
performance cam.
Would one have to
PS: Hope you win.
