Hi Triumphants,
I've been away from my '59 TR3a for way too long and am trying to get back in its good graces. Just finished rebuilding the master and slave clutch cylinders after the hydraulics getting to the point that I couldn't get into first or reverse. If I can do it anyone can. Please feel free to ask questions as I have just done it. It really wasn't bad at all...and it actually fixed the problem the first time...which is a pretty amazing experience for me and
mechanical fixes.
In any case what I wanted to get was a defintion of 'blow-by'. What I am calling 'blow-by' is when I look at my
oil cap and see smoke coming out. The car is running really great and has since I have owned it but there has always been smoke ('blow-by'?) coming out of there. I have done some research on the web and have a vague idea about the primitive crankcase ventilation system on my trusty TR3.
My uneducated impression is that air is sucked in the from the strangely shaped pipe that is on the side of my engine on the drivers side...and it exits through the oil cap. I am assuming also that the reason I have this foul smelling smoke coming out of there is because my bottom end is in need of a rebuild. Most likely my rings are doing a poor job of sealing the compression chambers and oil is passing by them and then getting burned thus producing the 'smoke' that I see. Of course it is most obvious when I lift the hood after a run. When I am moving along it is not visible, though it is smellable, until I come to a stop. I have had the car for the last 4 years and haven't driven it nearly as often as I should but it at least gets a run around town every couple of weeks. What I am wondering is if I am correct in thinking that this is a problem with my rings and/or the shape of the inside of my cylinders and if it is
is there anything I could do about short of rebuilding the bottom end of the engine? I have heard that the 'mystery additives' found at all auto stores that promise to free up
your rings and stop all oil burning are largely wishful thinking.
The top end was rebuilt maybe a thousand miles ago so I am pretty confident about the integrity of that side of things.
I am going to start driving it more and keeping real close track of how much oil it is using but I know that it does use oil.
I suppose my main question is if there is anything at all I can do to postpone rebuilding the engine. It runs so nice and I have never done a rebuild before but I guess there is always a first time. There is probably not a whole lot anyone can tell me if I don't know how much oil I am burning
off but if someone could just explain in more detail than I have now what causes this smoke from coming out of the oil cap I would really appreciate it. I have always gotten incredibly good information from this forum.
Thanks very much,
Jim Lee
1959 TR3a TS50550L Black as the night
mechanical fixes.
Thanks very much,
Jim Lee
