Jim_Gruber
Bugsy IV's Rear End received several coats of Gloss Black today and tomorrow will start the reconstruction process. Springs are all painted just need to bolt them together. 3.9 Diff needs a bit of Aluminum colored silver, on it before I bolt it back in, and new 207FF Sealed Wheel bearings and seals are ready for install. The PS Big Nut did not want to come off and finally needed to resort to using the Impact Wrench to break it loose.
Hylomar on the Diff mating surfaces or something else? And the 207FF Wheel Bearings look the same on both sides. I'm assuming they can go in either way. I will reinstall Ring Gear out of the car. Thinking although it would be easy to reinstall the rear end myself without the Ring Gear in place, I think the axle needs to be in a nose down position to minimize chances of tearing the gasket.
Will start reinstall over the next few nights, will need to install new backing plates, and lengthen E-Brake Rods and likely re-bend brake pipes. Need to bleed clutch, brakes, new gas tank needs install and some fettling and I'll need to crawl in he boot once I'm back on 4 wheels to attach the Sender wire to the harness. other than that Bugsy IV should be ready to start his Spring 2017 adventures. I can't wait.
PS New Alternator from BPNW arrives tomorrow. Same case as the Generator so it looks period correct. They even make alternators with Tach Drives as well that look just like the Generator. Pretty cool and looks period correct.
Driving soon Bugsy, Driving Soon I promise. Car and Driver are chomping at the bit. View attachment 48494View attachment 48495
