sim
no the distributor is the new style. I have good spark out of the coilCan you fit a set of points and a condenser? Just as a test. Could be just a weak spark from the pertronix.
Hi
I think this coil is ok as it is only 2 years old.
thanks
rod
I will share with you some data......at the risk of jumping into the "my taillights don't work", followed by "change the coil".....Hi
thanks
rod
If you want to just throw parts at it, and not be certain of the problem, you will end up with a lot of time, effort, and possibly money
If you don't have a Phillips to stick into the plug boot and try, a Phillips is a good tool to have, so you might want to purchase one.
Dave
Back from vacation I just order these https://www.aircraftspruce.ca/catalog...pkplugwire.php 7mm wires and 1/4 in shielding.except...if you read back...they didn't.
"Was going up a hill and lost one cylinder due to no spark. The other 3 went off one after the other before the top of the hill."
He has said new plugs fixes if somewhat. I keep thinking heat or something in the fuel. But without any further information, like length of spark, hard to tell.
Things have sure changed. every 2 years WOW . I just bought solid cores and will slide them into a braided cover to make the electronic distributor happyMy guess is not enough spark.
My six volt positive ground vehicles do more than that.
Carbon core wires....manufacturers used to recommend two year replacement intervals, if I recall.
I just use Belden solid cores, and I have one set been on the car for at least 30 years.
yes they want carbon core but going to use copper core with grounded shields. will post a picture when done. Ya not enought spark caused by carbon core wires i think.I think that Pertronix recommend's carbon cored if I remember correctly. I also believe you are not getting enough spark.
Kurt
every thing was replaced 2 years ago New Pertronix Flame Thrower Electronic Distributor cap and rotor new wires new plugs and Pertronix Ignition Coils not sure which one[FONT=Arial, Verdana, sans-serif]. all bought from Moss. if any of these items besides the wires are bad, I most likely will switch back to Lucus the prince of darkness. As the new stuff is far worse.The old rule was ten thousand ohms per foot. Measure them.
New wires won't fix lousy spark at the head end.
The spark you get out of the coil isn't good, and that's not even including the rest of the wires.
Out of that system, at the end of the coil wire, you should be throwing over 1/2" blue.
"Over time however, with heat and vibration the carbon fibers tend to loosen which degrades conduction and eventually requires replacement. For this reason some OEMs (original equipment manufacturers) recommend replacement every 3 years or 60,000 KM. Carbon core wire is quite economical for manufacturers to use while suppressing sufficient RFI. This wire typically has a resistance of 3,000 to 20,000 ohms /ft. depending on the manufacturer."
