R
RonMacPherson
Doc, we are all "suppositioning" here. But I agree with you being on the right track as far as increased resistance.
BUT, it may not be internal in the starter. He said he cleaned a cable and it started again.
My experience with these "rrr-rrr'ers' when warm has been external cable terminal looseness, corrosion buildup, etc...
So, before he goes internal in the starter, I would recommend pulling the battery terminals and scraping the posts and terminals clean, tightening them, checking, unloosening bolts and retightening each of the ground bolts, battery positive nut, make sure the negative cable grounds at both the frame and the firewall bolt.
