Jim_Gruber
I'm looking at pics of a BE Bonnet I'm looking to acquire that appears to have been de-seamed. Well seam is there but the beading has been removed. Are fenders spot welded to the bonnet? Guessing that's what holds them together.
Anyone got experience with either replacing beading or whats it take for surface prep to make sure paint will hold in those seams. Bonnet has been stored indoors for past 25 years and ot really solid from all appearances. Lower valence was replaced from a donor bonnet and filled with lead? not Bondo. Done right the old time way, 25 years ago and has bee nsitting. Wondering what to do with those seams when it comes time for final paint. I'm sure Bondo won't hold in there with bonnet flexing if I use front tilt hood setup.
Open for ideas.
Open for ideas.
But you don't have to be "old" to do lead. the difficulty will be getting the surface really clean down in the joint. But that will be a problem with any filler, not just lead. The hard thing about doing lead is that it want to run off anything but a flat surface if you overheat it the slightest bit. Filling that seam is about the easiest application there is for lead.
