DrEntropy said:<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Here's what I don't understand, if these are the cars for a dual set up, why will I need smaller anything if I use just one. If two cylinders don't make enough vacuum, I don't see how one could.
hooey said:I would start with the 28 chokes and pair of trumpets to hold it all togeather
DrEntropy said:You're causin' your own headaches, Billy.
hooey said:work on one problem at a time
if the ignition is working good now
fix the carb problem
then work on the ign
DrEntropy said:AMEN!!!
Every time ya introduce another varioble you COMPLICATE the problem.
JUST SWAP OUT TH' CHOKE TUBES, DAMMIT!!!
...or take it to someone who actually knows what to do. You're causin' your own headaches, Billy.
hooey said:DrEntropy said:AMEN!!!
I hear that![]()
kellysguy said:I want to clean up the Alfa carbs. Somene mentioned a leather shaft seal on these. Do I have to pull anything off of them before I soak 'em or just go ahead and teach them to swim?
