I bought a set of Datsun 280zx turbo alloy wheels to go on my TR6. However, when placing the wheel onn the hub I noticed that the Triumph wheel studs are now to short and don't protrude far enough through the wheel holes to get the wheel nuts on. The wheel seams to be much thicker than the old steel wheel. Also, the stud holes on the wheel are slightly bigger in diameter so the original wheel nuts wouldn't bolt on right anyway. I almost need a wheel nut that goes around the stud and through the wheel holes to make up the diameter or buy longer bigger studs.
Anyone know what the right answer is?
