64rocksprite
I started my rivergate conversion last weekend so I can get the engine/trans back in the car and continue assembly.
Today I was pulling the clutch fork and bearing holder..I noted some side-to-side movement on the input shaft. If I had to guess..I'd say 1/16-1/8" of total movement. I can't feel any end-to-end. Is some play normal or am I in for a tear-down?
Second - the old rear seal (and shroud); can I pull this with a gear puller with legs on the shroud or will it simply bend and leave me with a mess?
