Re: Datsun 5-speed Gear lube recommendations neede
Shear strenght enabled lubes are needed in the 210 Tranny. You might get away with motor oil, but eventually it will catch up to you.
If 90w is causing a problem try lighter weight. Redline used to make a lighter oil, I think it was 75w.. But you do need a GL oil in these trannies for best operation. i.e performance and reliability.
