I'm om the third dash wiring harness that does not fit my 1970 Plus 2 S 50/0023N Federal. This one is the closest of the three to the original but the colors do not match the old harness nor the closest diagram I can find, which is marked Plus 2 Federal 1968 - 1969. Mine was built in early 1970. There is also some slight variation in the branches, which I could live with if that was the only issue. While the old harness colors have badly faded, particularly the striped ones, quite a few of the solid colors are still distinct and I can't imagine why the new one would be so completely different. I can also find no compliance with any British wiring convention.
I started this a year ago and with Covid limitations in the UK there was had about a 3 month delivery time for each harness so my project has certainly gotten old.
In short, I have abandoned the hope of getting a replacement harness and am awaiting the arrival of bare cable from Autosparks in the colors correct according to the diagram that I have and to build a new harness.
I am hoping to match the new wires with the old wires, that are mostly tagged, with the correct color code on the diagram and the correct pins on the multi connectors to the engine (main) harness. This will be a tedious process at best.
This seems straight forward enough but an awful lot of room for errors and will be a very slow process. I'm also open to suggestions as to the idiot lights which seem to be permanently connected to the harness. Does anyone have experience with those? Of course I could always put a connector in the wire but I'm trying to keep the crowded mess behind the dash as clean as possible.
I'm no wiring expert so would appreciate any comments, suggestions, similar experiences, notes, diagrams or perhaps just wish me luck.
Thanks in advance,
Tom
Thanks in advance,
Tom
