Ok so here is some advice. You have two screws on the bottom under the bottom lip deep inside where the plastic shifter surround ends. You have two where the heater controls are. Also you will need ot remove the light bar above the radio that there are two screws there in slotted looking holes. Now the last two screws are one on each side towards the front of the car behind the knee pads.
Thanks Mike, I'll have to try and play with it tommorrow, had to do yard work when I got home from work today. Want to make sure all the wires are hooked up right, one my speakers keeps cutting out, and I want to hookup a 6 disc cd changer.
Tom
