TR6 Dash light issues
ichthos
Been a while since I have been here, but it is good to be back. My first TR6 was crushed by a tree, but I was able to find another 69 TR6 just a few serial numbers away. I have been busy transferring parts from it to my “new” TR6 As needed. I presently have no dash lights. I have had my hands up in the wiring as I had to change out two gauges, but I cannot find any wires that are disconnected. My first thought was it is a grounding issue, but the ignition light, wiper, and washer work. None of the gauge lights work. I checked the fuses under the hood too. Any thoughts on how to proceed?
Gliderman8
Have to ask... Have you check the status of the bulbs to make sure they are working? Also, you should make sure the base of the bulb holder is making a good ground.
Lastly, does your car have the rheostat for dimming the bulbs? You might check that to make sure it is also working.
RGK
Having the same issue, but have not started trouble shooting yet. Will probably start on it this weekend and post if I find something. Do you have a wiring diagram?
Platinum
Are the parking/headlamps working? If not, voltage supply at the switch (should be a solid brown or blue wire, constant 12V, not ignition dependent) needs checking. If so, then the switch and/or connection to rheostat, or rheostat itself could be the problem. A VOM or 12V test light would be needed for "chasing electrons" through the system. Instrument lighting will be solid red for voltage in, red with a white tracer from rheostat to bulbs. Headlamps will have solid blue for voltage in, blue/white for high beam, blue/red for low from dimmer switch. Black is ground in all cases.
All that is dependent on there being original wiring, not someone being "creative" in the past, IYSWIM.
poolboy
Have you checked the connection at the grounding spade for the dash ?....It's in the engine compartment between the battery and where the heater hoses enter the firewall
I
ichthos
Thanks for the suggestions. So, here is my progress. I checked the ground to the car and cleaned it. When I first got this car I switched most of them to LEDs, so I am pretty sure they are good. My headlights, rear lights, marker lights, and turn signals work. The turn signal and ignition bulbs come on. The dash lights were working when I first bought it, but it has been sitting for a year. Is There a way to bypass the rheostat to see if it is the culprit?
I
ichthos
So, trying to get at the rheostat. I was going to try just connecting the rheostat wires, but i can’t even get my hand in there. is there a trick to getting at this to remove the wires?
RGK
My understanding is you go in from the passenger side. I will be trying this weekend with a test light which should be easier than getting my hands in there. I am almost certain the rheostat is the culprit. It can be cleaned or bypassed. Dan Masters 'Electrical Maintenance Handbook' is an excellent reference, well worth the money.
RGK
Can anyone identify this, it is hanging from the dash left side of steering wheel. Voltage stabilizer?
poolboy
Looks like one..TR6 has it attached and grounded to the speedometer housing....not hanging loose
2 green G wires on the B terminal and a lite green LG to the temp gauge on the I terminal
RGK
So if it is just hanging, it is not grounded, which would affect anything connected to it? My temp gauge does not move with engine temp.
poolboy
Yeah the wiring schematic shows it's grounded by attaching it to the speedometer case which is also grounded
I suppose you could just test it by attaching a jumper wire from the stabilizer case to a good ground.
Be sure to check the ground connection on that tab I mentioned earlier that's in the engine compartment
Credit to Jim Herter for the original picture
RGK
I had checked that ground, it had been painted over so I dremeled it shiny. I will ground it to the headlight dipper with a jumper and see what happens.
No change with the jumper. All dash lights, wipers, turn and hazard lights out. I will start checking connectors from the fuse box tomorrow.
RGK
For icthos; from the passenger well the red & R/W. I would have to remove the radio to get my hand up there, might be able to take the rheostat out from the front if there is enough slack, but have a feeling there is no power to it.
Gliderman8
I just by passed my rheostat about a month ago. I removed the passenger footwell speaker panel, as well as the rheostat knob and screws holding the rheostat in place. With some patience I was able to remove the three wires on the rheostat. I made a three-wire connector to hook them together.
RGK
That is good to hear the rheostat does come out the front. I want to make sure there is power coming into it before taking it out. I have a few confusing electrical issues going on.
Gliderman8
No, the rheostat does not come out of the front. I removed the screws and pushed it into the dash and then I was able to remove the wires.
When I was done I pushed the rheostat back into the hole and reinstalled the screws.
I
ichthos
Well, it was the rheostat. This is my third TR6, and I never had one fail before. I temporarily connected the wires. Once I get everything working, I have to replace the horrible dash, and then I will just replace it with my spare. Thanks again for all your help.
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
L Light for BJ8 Center Dash Panel Austin Healey 17
I Bugeye dash light problems Spridgets 9
gbtr6 TR6 Need a plastic dash light plinth Triumph 17
A TR4/4A Turn signal dash light inop? Triumph 6
JimTR4 TR4/4A dash gauge light wiring Triumph 3
K TR4/4A Green and Red Warning Light Removal from Dash? Triumph 5
K TR2/3/3A Dash panel light bulb colour options? Triumph 5
D Dash light bulbs Spridgets 7
T TR2/3/3A Flasher indicator dash light Triumph 3
S BT7 Dash Gauge Light Bulb Replacement Help Needed Austin Healey 16
A TR2/3/3A Dash light switch Triumph 2
A TR2/3/3A Dash light switch Triumph 0
B Dash Light Replacement [not with LED] Austin Healey 6
T TR6 TR 6 Brake light on Dash Triumph 4
K TR2/3/3A TR3 red-light on dash again Triumph 5
K TR2/3/3A TR3 Red dash light stays on? Triumph 4
S TR2/3/3A dash light variable resistance tr3 Triumph 8
jdubois TR2/3/3A TR3A directional indicator dash light Triumph 4
Gundy Dash light question Spridgets 2
M Red dash ignition light glowing very little Spridgets 16
budk1953 Dash light rheostat questions Spridgets 3
TimK Mystery light on dash [BN7] Austin Healey 11
T yellow dash light Triumph 3
roofman Dash light fiasco Triumph 23
Jim_Gruber Need Light Bulb Socket / Turn Signal / Behind Dash Spridgets 1
M Spitfire 76 Spitfire dash light help needed Triumph 11
Brosky Brighter dash light bulb saga continues Triumph 17
Tinkerman Polishing dash light plastic. Triumph 7
Brosky Dash light bulbs Triumph 51
A dash light cut off switch Austin Healey 9
drooartz Dash light sockets Spridgets 2
zimmy red light on dash Spridgets 6
mgbnew Regarding red light on dash MG 8
mgbnew Red light on dash board MG 13
jcatnite Red Light on Dash Spridgets 22
F dash light [signal] Austin Healey 4
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
