The indicators on my 65 BJ8 MkIII don't self cancel consistenly so I want to add a 12v buzzer to the circuit so I can hear when they flash and remember to cancelrather than looking like some old deaf bloke who can't hear the flasher unit. Before starting to install a buzzer I checked the indicators and they work fine in all respects except that both dash indicators lamps flash together for both left and right indication. I've checked earths on the four indicator lights in the body, all are ok and all lamps are bright and flashing at the correct speed etc. The circuit for the dash mounted lamps do not seem to have an earth return. The lamps return to the centre pin on the flasher unit. Should that centre pin (dark brown/green wire ) be earthed? Has anyone had the same problem with both lamps flashing and if so, what was the solution?
Thanks
Ian Irving
Thanks
Ian Irving
