Stewart
Perfect day up here and most likely the last time this place will see 60 degree temps till April and low and behold the clutch system goes belly up.
I had some issues yesterday with hard shifting while stationary and the clutch engagement point moved closer to the floor. I figure the was air or moisture in the line as it's been god knows how long since its been flushed. Clutch hydrolics were the only working system when I picked up the car. Went to bleed the lines and had no luck getting fluid to flow. Even with vacuum on the bleeder I could not get the fluid to flow. Since I was down there I went ahead and changed the slave cylinder and am I wrong in thinking that the master has gone to the great MG graveyard or could it be something else?
