Biff
Re: Dampers popping out of the dashpots
Check the TIMING................
If the intake valve(s) is still partially open when the plug fires it will back fire out the intake, i.e., timing is too advanced.
Again check the TIMING. It was mentioned earlier but I saw no reply that you have checked it. Again with advanced timing there will be less and less power as the revs go up because the distributor will be adding more advance.
