Wanted Dampener Tr4a crank pulley
Milo
I’m removing the fan and extension from the pulley and need a dampener pulley. New or used is fine. I’m in Australia so I’ll pay the freight 😀
A Holden harmonic balancer can be adapted via the use of a spacer....But pulley groove is narrower...You would need to change the pulley on your water pump, or fit a 6 cyl TR one...[bolt spacing is slightly different, but will work]
Yup just the pulley is all. I have both a wide and a narrow belt pulley for the water pump. Cheers m
Has anyone ever figured out how a harmonic balancer can be adapted to an MGT series engine? PJ
Milo,
good pulley with hub. $75 and shipping
Marv
