Hi Folks,
The spring rains have cleaned the roads of salt and we now get a glimmer of sunshine from time to time.... time to wake the sleeping beauty.
I took out the 4A for a little shakedown run about 2 weeks ago and felt a noticeable drop in power .. a bit sluggish. Checked the carbs, fuel delivery, ignition components... all fine. As the engine has about 650 break-in miles, i dropped it off at my mechanic for a once over and a compression check and just got a message from him that the #3 cylinder is way down at around 80 versus 150-ish for the others. Now the question is what could be causing this? All internals are new. Maybe a valve is not seated well.. or worse, the head is leaking ie. warped? Any comments are appreciated.
many thanks,
Brett
many thanks,
Brett
