cylinder head torque
ceedub
I am ready to re-torque the head after my rebuild but cannot find if the torque setting for the head is for a warm or cold engine. The valve settings appear to be for a warm engine. So do I set the head cold and then the valves warm?
tony barnhill
Great Pumpkin - R.I.P
Torque the head cold & retorque again after about 500 miles.
billspohn
He didn't say if he had a stock or alloy head and the techniques are a bit different.
The cast iron head gets torqued cold, then run until at operating temperature and retorqued.
The alloy heads are torqued cold, run up to heat and then allowed to cool completely and rechecked. Seems to work best.
Scott_Hower
Good info.
When retorquing... is the protocol to loosen each in the tightening order and then retighten? Or loosen all then tighten in order. or does it not matter?
For example, loosen only #1 in the sequence, then retorque. Loosen #2, then retorque. And so on.
Or loosen all slightly then torque in order according to sequence.
I'd imagine it's the former, but I dont remember the manual being specific.
jlaird
I have never loosened head nuts unless I was takeing the head off. Just check what you got.
Kuz
Just retorque the bolts,don't loosen anything. Start at 5 footpounds below max, then max twice all in sequence.Keith
Bugeye58
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif
I've been doing it the same way for a lot of years, and that method works for me.
Jeff
Platinum
I assumed cast iron (MGB). But Bill brings up a good point: alloy vs iron.
The collection of rolling stock in my .sig file has all-sorts as combos of iron and alloy. Each requires its own different proceedure if re-torqued. The Alfa (alloy head, wet-liners in an alloy block) is the biggest PITA: torque, heat to "normal operating temp", cool to ambient, retorque... "wash, rinse, repeat."
And don't EVEN think of rolling off in "winter" climes until the temp gauge at least twitches off the peg.
When I lived in western PA I used to buy Alfa head gaskets by the ~six-pack~!! /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Steve_S
There is much debate on the subject, but I always loosen a tiny bit to eliminate stickiness while torquing. This way there is no false reading due to a nut not breaking loose before the torque wrench reaches it's maximum setting. I'm talking 1/8 of a turn or so, and I do them one at a time.
Platinum
Yup. "crack" it loose then give it the tweak... and in order.
billspohn
Agree - only way to get a reliable torque figure - otherwise they can 'stick'
Steve_S
Kuz said:
If you used anti seize they won't stick. If you didn't your torque is probably inaccurate
That depends on what studs you use. Some require lubrication and some require no lubrication be used. You need to check the manufacturer's specs before torquing.
Platinum
Makers' spaec's can call for either. "Dry" or "lubricated". It's a RTFM deal.
tony barnhill
Never thought about backing them off a bit before retorquing! Guess it wouldn't hurt...don't know what it gains....
Platinum
It breaks the corrosion/rust/electrolysis and gives you a more accurate torque. If you just tug on it without "breaking" the resistance you can overtighten or not get a smooth turn to proper torque. Even with a bit of "goose-grease" on the threads it's a good idea to back 'em off a bit first.
tony barnhill
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]It breaks the corrosion/rust/electrolysis and gives you a more accurate torque.[/QUOTE]
After 500 miles?
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]If you just tug on it without "breaking" the resistance you can overtighten or not get a smooth turn to proper torque. [/QUOTE]
If you back them off before using your 'click' torque wrench, you'll never know if there was a problem with the initial torque 500 miles earlier.
Scott_Hower
Welcome to BCF and thanks for the input; I use antiseize on any stud/bolt that may gall from dissimilar materials and/or come in contact with water.
I've never seen a factory spec for using antisieze paste on head studs. The spec (as stated in my copy of B-Series Engine Data) is usually engine oil or dry. Most specs list wet torque w/engine oil. Copaslip, et al, was widely available at the time.
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
M Proper torque for cylinder head nuts Triumph 20
Bruce_B Bolt torque sequence on 11 bolt cylinder head 1275 Spridgets 7
T TR4/4A TR4 Cylinder Head Bolts Re-torque Triumph 4
I Torque setting for BN1 Cylinder head Austin Healey 2
S Wedge proper torque for TR7 cylinder head Triumph 8
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 2
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 21
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR2/3/3A Cylinder head threaded plub Triumph 6
R BJ8 Cylinder Head Gasket Austin Healey 38
M Alloy cylinder head Austin Healey 5
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B General Tech Cylinder head costs MG 7
J For Sale TR 2, TR 3 TR 4 cylinder head Triumph Classifieds 6
J TR2/3/3A TR 4A cylinder head on TR 3 engine Triumph 15
M Planing a Jaguar cylinder head Jaguar 4
RJS TR4/4A Cylinder Head Install - Questions Triumph 16
C Wanted - 3000 cylinder head - uk based Austin Healey Classifieds 0
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Wanted 3.4 Cylinder Head Jaguar Classifieds 3
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
HealeyBN7 Is this a 100 Cylinder Head? Austin Healey 4
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
SherpaPilot TR6 Cylinder Head Stud Question Triumph 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
K TR2/3/3A Cylinder head valve springs? Triumph 3
