AUSMHLY
Hello,
Reference BJ8:
My understanding is ARP studs/washers/nuts are an upgrade vs the factory/stock cylinder head studs/washer/nut.
The stock stud for the BJ8 is about 5 1/8" long.
I purchased ARP studs that are 5" long.
The stock stud 7/16-14 thread for the block is about 5/8" long.
The ARP stud 7/16-14 thread for the block is about 1" long.
I've read the studs should be installed finger tight into the block.
The stock stud is finger tight when the shank makes contact with the block head at 5/8" depth.
The ARP stud is finger tight when it makes contact at the bottom of the hole, more then 5/8", because the threads are 1" so the shank doesn't make contact.
Because the ARP stud is lower in the block, it doesn't extend enough into the cylinder head nut to use all the threads.
Would it be safe acceptable to hand screw the ARP stud 4/8" into the block and stop there?
That will allow the APR stud threads to protrude the nut about 1/8".
Photos attached:
1. Stock stud next to ARP; notice the length of the threads.
2. Both studs taped to show how far they enter the block.
3. Stock stud inserted finger tight until shank. ARP finger tight to bottom of block thread hole.
4. How far ARP stud extends into the cylinder head nut.
5. Stock stud inserted finger tight until shank. ARP finger tight 4/8" into block.
6. How far ARP stud extends into the cylinder head nut.
Stock stud inserts 5/8 into block.
ARP stud inserted 4/8" into block, OK?
I've added a thin silver washer to compensate for the gasket thickness.
Thoughts?
Reference BJ8:
Photos attached:
Thoughts?
