Deleted member 21878
why the third wire to the cut-off switch in the trunk? (white/black) is this because of some charge left in the coil?
Thanks
Thanks
Thanks
I think most of the switches that are unreliable are at least 50 years old. I replaced my old one ~20 years ago with a genuine Lucas switch and it has been fine.i have read in a few places about their reliability. i am surprised someone has not made a look-a-like replica that is more dependable.
They can be 'restored.' They're just a pair of spring-loaded rotating/sliding copper plates inside. I think the copper plates just get corroded over the years; a little cleaning and some dielectric grease should do the trick.
Be sure you tape up the end of that white/black wire so it won't touch ground/earth. Otherwise you will suddenly stop.I cleaned the switch today. Good thing. Took a few minutes to figure out how it goes back together as it popped apart. But I got it. Since I do not have the engine in yet, I left the white/black wire off. ...
... I think the Lucas switch needs to be thrown away versus rebuilt. It will always be an inferior piece of equipment likely to fail as is borne out by the frequency of our having to talk about it.
Certainly the original switches can be repaired but they will still be susceptible to the same possibility/likelihood of failure, specifically due to internal corrosion on the copper parts which are naturally prone to go green. High quality shut-off switches--particularly those for marine applications--have anti-corrosion plated conductors, just as the best quality wiring is tinned.
If one likes the look of originality--but does not want it to extend to being broken down alongside the road--keep the original POS switch installed with no current-carrying wires and have another functional one concealed either in the boot or behind the bulkhead, and in any case disconnect the b/w wire that grounds the coil as it can only lead to trouble.
If running an alternator consider getting a switch such as those sold at Pegasus, etc. that provides a circuit to ground/protect the alternator when the power is cut off.
This one won't look original but should be fairly bullet proof: https://www.pegasusautoracing.com/productdetails.asp?RecID=1464
Cheers,
Dan M.
