vettedog72
I understnad they should have a carbon film over the tops; it keeps the heat in the chamber and reduces the piston heat.
Which is the other problem, it raises compression and hence increases octane requirements. The coating is typically not just carbon, but other solid gunk from the fuel & it's additives as well; and can be a lot thicker than just a few thousandths. Back in the days of leaded fuel, it was mostly lead oxide that would flake off when it got thick enough (leading to problems with glowing broken edges), but unleaded leaves a much harder deposit. If your engine runs cleanly enough (all the time), the deposit may not even be black.poolboy said:And, a few thousandths of carbon may actually raise the compression ratio, by reducing the air space.
TR6oldtimer said:DrEntropy said:If you just HAVE to do something about it, wait 'til it's running again and mist some water into the throats at 3K RPM.
My old man use to spray a mixture of water and diesel oil into the carbs while the engine was running. He claimed it took care of carbon build up. The cloud of smoke was a sight to see. If I were to do that today, I'd be arrested.
He also would run a mixture of motor oil and diesel in the crankcase every third oil change to clean out sludge.
None of this appeared to harm the engines, but I'm not sure I would do any of this, however he learned about engines as a farm boy, and swore by these procedures.
I miss him....
TR3driver said:Just curious, Bill, have you checked the piston/head clearance ?
