Curious if these photos tell you anything about my car.
I did another compression test yesterday, this time after warming up the engine to temperature. Also, I only used 1 pump of oil into each cylinder for the wet test.
dry: 158/160/156/156
wet: 168/165/162/165
so, that's a 2.5% variance between cylinders and a 3-6% variance dry to wet.
I'd be satisfied. :o
Yeah, good. Less oil (see what I mean?) and lower end seems tight enough.
Guides are still wet, on your original photo, so you decide.
If you aren't leaving clouds of blue smoke at the bottom of a long grade, not fouling plugs, and not using significant amounts of oil, leave it.
We used to have a fellow in these forums who constantly bragged on running with a flat crank, so you can get away with a lot of stuff....like cams 30 crank degrees advanced, pistons hitting valves for 8 years at least, Mercedes carburettors, brazen breaker plate in distributor....that kind of stuff.
Yeah, I think I'll be content with it as-is for the time being. I'll keep an eye on things. Maybe some valve work in the not too distant future.
