Curious Carb "Accessory" 55 BN 1
Gray_Cat
I've rebuilt and tuned the carbs on my 55 BN 1 (many thanks Dave!) and have a questions about a couple of "accessory" items on them. At the bottom of both carbs there is a very slender tube (copper) that is plugged at the end with a very small hole just before the plugged end. Each tube is atached by a fitting to the bottom of each carb and are about 5 inches long. I've never seen anything like this and cannot find reference to them in my SU manual or shop manual. Anyone know what they are called and their function?
Many thanks - Roy
Bruce Bowker
If I am understanding you correctly I believe these are "overflow/drain" tubes.
I think there is a reference to them in
Austin-Healey 100/100-6/3000 Restoration Guide (Authentic Restoration Guides)
Bruce
Dave Russell
Yoda - R.I.P
I believe that you are referring to the "manifold drain pipes"
You can see them as item 36 here:
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=28851&SortOrder=35#top
They are originally long, small bore pipes attached to the bottom of the intake manifolds. Note that they extend to approximately the oil sump flange. The purpose of them was to "drain" excess fuel caused by flooded carburetors. Their very small bore & long length prevented them from inducing a major manifold air leak.
I personally consider them to be an unneeded extra since the carbs shouldn't be flooding in the first place & it is questionable how much fuel they could drain out anyway. I just soldered the fittings closed & left the pipes off. Moss lists them as not available. With millions of cars running around with no manifold drains, I don't personally think that it was a particularly good idea. I have never had an SU carb in good condition flood.
If you feel that the drain tubes are an advantage, or wish to be totally concours correct, you will need to find some very small bore tubing that can be full length. Note the small holding clips down near the oil pan flange. The long length & small bore reduces the effect of the air leak into the manifolds.
It appears that on your car, someone has used shorter pipes with a small drain hole drilled near the plugged end. While it will probably work, the problem is that the short pipes will drip fuel on the hot exhaust system. Not so good! Later engines used a short metal pipe with a plastic hose extension. The plastic tends to melt & is hard to route out of harms way. The tri carb engines did not have the drains. Take your choice.
I found them at British Car Specialist along ith the metal holder at the oil sump. I am not sure of their need but there seems to be a few drips after the engine is turned off which seem to evaporate. I couldn't tell you if it drips while running. But mine connect to the bottom intake manifold. I didn't get that from reading the post. But I have a BJ8.
Gray_Cat
Gray_Cat
Many thanks guys! I misspoke saying carb when the tubes attach to the manifold. I managed to move them enough that I believe it is safe to leave them on for now. I may remove or plug them later, I just had never seen anything like them before.
Roy
I would go with long ones or plug them. Short ones drip in dangerous spots. If you plug them, all you have to do is remove the "nut assembly" at the manifold and drop metal disc(nail head)into it and screw it back up. Thats how mine came from the PO.
D TR2/3/3A curious tachometer take-off Triumph 5
D TR4/4A now I'm curious Triumph 7
glemon Curious Part II Spridgets 0
N Curious?? Spridgets 13
matmire Curious if these photos tell you anything about my car. Spridgets 24
M_Pied_Lourd TR2/3/3A Just a Curious TR2 Question... Triumph 3
J TR4/4A TR4A Just Curious Triumph 15
M Just curious Triumph 20
B Curious question..Engine Coolant container MG 10
5 Curious BN4 engine pic Austin Healey 3
M Curious Spridgets 42
M Just curious Oil Question Spridgets 5
Jim_Newman A Curious Hole Austin Healey 5
K Curious about 1966 Jaguar S-Type Saloon Jaguar 5
T Just curious - 1971 Jag XKE 6 cyl value Jaguar 13
SkinnedKnuckles Just Curious - Where are the Old Pro's Triumph 28
G Just curious while waiting on parts!! MG 30
B I'm just curious- what do these fit? Spridgets 4
wkilleffer Curious about compression check results MG 5
JPSmit Tonights curious solution Spridgets 3
AUSMHLY Curious, what is the most view topic Austin Healey 3
G Curious.... Triumph 30
JPSmit Curious ad Other British Cars 11
ronzet Curious glowing on my Tail lamps MG 28
G Just curious Rover / Land Rover 1
T Curious holes? Triumph 1
D BJ8 Interior Panels - Just Curious Austin Healey 3
G Curious.... MG 24
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
