Tinkerman
I am very close to finishing the dash area. I lack installing the speedo and tach gauges and the cubby box. Waiting for the correct "O" rings for the gauges so I thought I would work on the cubby box. Doesn't seem to really want to go into the space allocated for it. Is that typical? Are there some little tricks that I should know about? My action plan is to trial fit it and then install the door. Then permanently install the box. Make sense?
Any thoughts and ideas would be very helpful!
Additional question. Does the wiring harness go above or under the right hand side dash bracket?
Thanks, Tinkerman
Thanks, Tinkerman
