Brosky
Years ago, GM came out with what looked like a Bakelite plastic float to eliminate the solder joints cracking on the two halves of the floats in their 4BBL carbs. This worked well after they eliminated the bad ones that were porous and took on fuel like a sponge.
My point and I do have one, is that if you have this apart again, check the float by submerging it in water to see if it will stay under, or float to the top. You may have to keep it under for a while, in the event that there is a hairline crack in the solder or if the float metal is taking in fuel and allowing it to be too heavy.
You can generally hear the fuel sloshing around in the float when it takes it on, if there is a hole somewhere.
Only a few grams will cause it to be too heavy and create the flooding.
Not a definite answer, but worth checking in advance, before reassembly.
