Re: Crypt Update
treat it very carefully so that it doesn't bend.
The old pump probably belched a bunch of dirt into the carbs which is causing the gas inlet valve (which are hooked up to the float) to stick open and overflow. I believe that you have Stromberg carbs so....
To solve this problem: Take the carbs off, take the bottom cover off there are 4 screws which hold it on. The bottoms should come off easily. The big thing that flaps up and down is the float. It controls the little valve which lets the gas in. Make sure that the float moves smoothly (freely) and that the valve closes when the float rises. If there are bits of old pump in there, the valve may be sticking open and causing the flood. Just be careful no to bend anything. The gas volume in the lower portion of the carb is controlled by the hight / angle of the float, and if you bend the needle valve then it will leak, and flood.
Once it is clean, put it back together and go for a victory drive.
Yisrael
Tinster said:says YOU!!!
BTW: What do I do with the needle valve once I find it?
d
Yisrael
