Rocky_LC
Yesterday I was driving my car (‘71 TVR Vixen 2500 with the TR6 engine) up Mount Lemmon with some friends. It’s a 26 mile uphill drive to a little town.
I was about milepost 14 when the engine just suddenly completely cut out, and I lost all power. I was able to steer over to the shoulder, and the engine died as soon as it wasn’t being driven by the wheels.
Of course, a failure like that seemed that it must be related to the ignition. So the first thing that we did was pop the distributor cap, check the rotor, and check all the wires going to my Pertronics ignition system. All was good.
We then verified that we had good spark from the coil (I accidentally shocked the heck out of my buddy!).
Since the ignition was obviously good, We took a look at the fuel. Even though it seemed to us that IF there was a fuel problem, the car would’ve cut out or stumbled, we convinced ourselves that it could be in the fuel pump. Luckily, I had one down in town, and we got it changed it out.
Still no luck! The car just turned over, and wouldn’t fire!
So we were back to ignition. We pulled the number six plug - it looked great! Then we decided to do an ignition check on the plug itself! No spark at all!
Luckily for me, I have been carrying a bunch of spare ignition parts, so we swapped out the rotor and the distributor cap. The engine immediately fired as soon as I cranked it!
We were both stunned, because the rotor and cap were nearly brand new.
Anyway, when I got home, I took a close look at the router. You can clearly see that there is a burn track where the spark was moving from the center of the rotor, from the river, and down the rotor body onto the distributor plate or shaft. I would never have believed it….
OBTW: This is the Lucas / Moss Motor “upgraded” rotor! Stick with the red ones!
Rocky
Rocky
Hi Guest!
